Radio wiring issue + HVAC bulb number?
Old Oct 21, 2012 | 07:29 PM
ReDRockStar's Avatar
ReDRockStar
Default Radio wiring issue + HVAC bulb number?
I was away at a wedding for 2 days. Came home..went to go somewhere..no radio. HMMM. When I bought it about a month, ago the radio in it was already dead...so I thought. Put another radio in it from a '00 Stratus. No problem. Now this. At my shop I have 2 other mopar radios with the same inputs. Before I got it working again, I tried the other radios. I know it's in the wiring. I could shake it, and it would flicker. the interior looks easy to take apart. Top of the dash took me 5 seconds to scoop out the rest of te top. Plus should easy to replace the dash speakers! Alot easier then a G1 Breeze/Strat/Ciruis. Wow going off topic..anyway. I have a test light of course at my shop. The dimmer works! So it should be the power wire right? Not a big electrician. I have access to ALLDATA too for those who know that. (well to me it's NODATA :P) Sucks having no jams being a drummer, but nice with it being 5spd
Also my bulb went out on my right side of the HVAC controls. What is the bulb #?
Thanks!
Old Oct 21, 2012 | 11:36 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Use the alldata wiring diagram and problem the wires on the radio pigtail and see where its not getting juice. Should need to test 3 wires, 2+, 1-. Not sure on the bulb. I would pull it and swing by the parts store with it.
Old Oct 21, 2012 | 11:40 PM
I_Ride_Neon
Pink should be hot all the time (fuse 13, 10amp)
Red/White is hot in the accessory/run position (fuse 16 10amp)
Black is ground, should clip to the back of the radio.
Old Oct 22, 2012 | 01:10 PM
ReDRockStar
HAHAHA found out it was the radio it's self. Replaced it with another one. No issues. Didn't have the ground hooked up to the other radio when I was looking for issues.
and the bulb number is 161.
stuff is so much easier when you're at your shop instead of home :P
