engine stutters at low idle
Would check throttle body for carbon build up. Clean gently but would start there. Also try a good bottle of injector cleaner such as Mopar top end cleaner or Reline Oil's SL-1 Fuel injector cleaner. Probably there. If automatic could be signs of a trans problem as well but start with basics such as first two.
hi again, the car is a manual and i put cleaner in it and not any better. how do i check for a bad injector, i had the mopar per. computer in it but took it out and it didnt help. im out of ideas, could it be a gas filter and where is it so i can change it thanks again!
Gas filter is in the tank.
Also check the injector inlet filter screens. Friend at school got advice from a techer (Auto tech school) that they look ok but actually varnish up. Only about a 25 Cents each so not expensive but it cured his idle issue. May try that. He got them at NAPA.
A thought and at least not very expensive. What's a buck or so.
I just got back from going to Florida and back here to Chicagoland and have just started getting that issue. Started when I got down there after spending 16.5 hours at about 70-80 Miles per hour. So might be doing mine soon. Will update with my results in a week or so. Probably looking at Saturday for Mr. FixIt time here.
But his varnished up about 25000 miles. Mine is near there and starting to act up just a bit. Just not as smooth as before.
Will try checking the plugs and the fuel injector screen issue.
