DOHC ecu?
Old Nov 3, 2012 | 04:33 PM
holset cummins's Avatar
holset cummins
Default DOHC ecu?
hey guys, i want to put a DOHC ecu on my car. now at my local junk yard, there are more DOHC Stratus than i could count so i was wondering if i could take ecu out of a stratus and put it in my 97 neon with no problems?
Old Nov 3, 2012 | 09:53 PM
I_Ride_Neon's Avatar
I_Ride_Neon
No. Needs to be a 97 dohc computer from a neon. You can use other year ones but you need to change some pins. A 95 for sure wont work.
Old Nov 4, 2012 | 01:57 AM
holset cummins
ok thanks. i am finding some 97 ecu on line but a lot of them are for auto transmissions. does it need to be a manual trans ecu to work or can i use an auto one?
Old Nov 4, 2012 | 09:17 AM
I_Ride_Neon
Yes an ATX one will work BUT the rev limiter will be lower, check engine light will be on for missing the trans sensors. I would hold out for a manual one.
Old Nov 4, 2012 | 09:20 AM
I_Ride_Neon
Give these a peak. Just a quick google search pulled them up.
http://www.ebay.com/itm/1997-Dodge-N...13ea2b&vxp=mtr
http://forums.neons.org/viewtopic.ph...7929&p=3348985
Old Nov 6, 2012 | 11:56 PM
das2123's Avatar
das2123
You can use a pcm from a 97-99 mtx. Can I ask why you want to do this? It will cause your car to run a little rich.
