best ecu for the power
Old Nov 6, 2012 | 11:00 PM
holset cummins's Avatar
holset cummins
Default best ecu for the power
i am looking at getting an upgraded ecu for my 97 noen. there is two i am looking at which is the Mopar performance sohc ecu and the stock dohc ecu. which one makes the most power? let me know what you guys think.
Old Nov 6, 2012 | 11:53 PM
das2123's Avatar
das2123
Is your neon a sohc or dohc? The mopar will give you more power as it has advanced timing. The AF/x pcm strip is the best upgraded pcm for the neon.
Old Nov 7, 2012 | 10:07 PM
holset cummins
its a sohc. where do i find a mopar performance ecu?
Old Nov 8, 2012 | 08:04 AM
das2123's Avatar
das2123
Have to find a used one on forums. I may have a friend selling one. I will check.
Old Nov 19, 2012 | 11:15 AM
zilfer22's Avatar
zilfer22
you can find the mopar pcm on modernperformance.com or howellautomotive.com howell has the afx one as well
Old Nov 19, 2012 | 05:25 PM
das2123's Avatar
das2123
Neither have them anymore as they are no longer in production. You have to find a used one.
