?????neon no start do to gauges?????
Old Dec 29, 2012 | 04:31 PM
mirandaneon's Avatar
mirandaneon
Default ?????neon no start do to gauges?????
in reading why my neon wont start, even with fire and fuel and air, i came across an article that since my chech engine light is out or broken(does not come on when i first turn keys on) that it could be keeping my car from starting? any truth to this...
Old Dec 30, 2012 | 06:21 PM
go-part's Avatar
go-part
Former Vendor
The check engine light wont keep your car from starting, it will however tell you something is wrong.
Do you think the battery might be dead?
Does the car turn over?
http://www.riboparts.com/changeBlogs...eName=&id=2192
Old Dec 30, 2012 | 11:55 PM
ohioguru's Avatar
ohioguru
ur check engine light may be burnt out
Old Dec 31, 2012 | 04:52 PM
I_Ride_Neon's Avatar
I_Ride_Neon
No CEL could mean no communication with the ECU. But since you have spark and fuel I doubt that. Car needs 3 things to run, accurate fuel pressure and volume, timed spark, and compression.
Old Dec 31, 2012 | 04:54 PM
mirandaneon
Default ok
well then this thread can be deleted, as i have one open for the no start issue
