under drive crank pulley
Old Jan 28, 2013 | 06:53 PM
ohioguru's Avatar
ohioguru
Default under drive crank pulley
who makes a good one for under 100? and has anyone installed one? also post what you thought about it and if it was noticeable. also what is to gain from a adjustable cam gear? other than looks? and who makes a good cheap cam for the sohc motor its a dd
Old Feb 12, 2013 | 10:18 AM
mirandaneon's Avatar
mirandaneon
heard a cam out of the newer 2.0's are supposedly like having between a crane 10-12
also obx UDP of of ebay is dealable and usually less than 100
Old Feb 13, 2013 | 01:42 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Hes referring to the HO r/t camshaft. You will also need the valve springs from it. Or just swap the whole head for a better flowing head. An adjustable cam gear will only give you power if someone tunes it, otherwise waste of time. I dont like using under drive pulleys. Considering you removing the factory Harmonic balancer for something else. The name harmonic balancer should speak for itself. I have used unorthodox in the past with good result, just stick name brand. I may add the 95 sohc camshaft is a little hotter cam that doesnt need any springs or anything, just throw it in.
