stock flywheel weight in a 99 neon sport?
Doesn't that seem a little light though? I got a reply on another post saying 11.3Ibs that too sounds way lite... Idk maybe im skeptical cuz my friends suby's weighs 28 Ibs just the fly wheel.
Yah probably because the throttle response in my car is complete crap so a light weight would I suspect be awesome!
I would say on a high side 15-20 pounds. I pull clutches a few times a week, usually the car ones are pretty light. For the amount of work it takes to put the flywheel on, I would invest your time and money into something that will actually make a noticeable difference.
I have installed lots of them and think they are a waste of time. Plus I dont like the idea of using different material considering how dangerous it is to explode a flywheel and clutch. Bigger throttle body, intake manifold, header/exhaust, EGR block off, camshaft/head porting, tuned computer, maybe a little weight reduction. Those are the things I go for.
gotcha ill keep that in mind. I already have header, planning on cams and gears (already have them just not in yet). I was reading for the EGR delete that you have to run relays or something to egr sensor or something like that... is that true? Also how helpful is it? Does it effect gas mileage? Also have plans to do a automatic jeep throttle body cuz its like 60mm I read.
sorry for all the questions
Trending Topics
When you block off the egr and block off all the vacuum lines/nipples it will throw a CEL, you can get rid of the CEL by using a resistor. It wont effect gas mpg as far as I know. It helpful to the throttle body and head so they dont get gummed up with exhaust residue, and reduces the amount of hot air in the intake. jeep TB is the way to go, but I think the hold on the manifold is only like 56mm or something I cant remember. Cam gears are useless unless you have the car dyno tuned. Is the car a dohc or sohc?
Oh i see, what kinda resistor or how many amps? I have cam gears and would like to use them with my cams anyways so maybe ill do some research. The car is a DOHC with a header and 2.5" exhaust MSD ignition. I supposedly have a AF/X race computer i got off ebay for $200... im putting comp cams in my car as well
