LED problems
Old May 16, 2013 | 12:44 PM
SXX360's Avatar
SXX360
Default LED problems
Well, earlier this year I got pulled over 3 times for having my license plate light "out." It wasn't really out it was just really dim...
Anyways I bought a led light for that and also bought 4 more led bulbs to replace my turn signals front and rear.
I put the ones in the tail lights and then obviously had the ricer flash. Fixed it by cutting one of the traces on the circuit board of the relay(found the fix on neons.org) Blinkers work fine although they do flash faster than stock.
Next i put the led bulbs in the front turns and then all hell broke loose, the blinkers flashed really fast again which I can understand. The part I don't understand is that my license plate light now flashes with the blinkers and when the parking lights are turned on the blinkers dont work at all.
Next I guess is to get an electronic, led compatible, relay and trying turning the tail light bulbs around and see if that's what the problem is.
If anyone else has any ideas about this it would be greatly appreciated
