98 neon electrical question
i have a 98 neon 2.0 dohc. my problem is yesterday i was driving and suddenly i lost all power to the car (as if the battery was unhooked) the car would not do anything when trying to restart. i hooked up jumper cables and after about 5 minutes the car started and ran just fine. Today i drove the car for a while with no issues. after coming home for about 15 minutes i went to leave again amd the car started fine but when i put it in gear to leave it lost all power again. any suggestions as to what is causing this??? i dont know if its the battery, alternator, or wiring issue(hopefully not!) any help would be appreciated and thank you in advance
It ended up being a broken wire coming from the positive side of the battery terminal to the distribution block that houses the relays/fuses under the hood. Thankfully a simple and easy fix. Thanks for the advice
