Compression ratio???
Old Sep 29, 2005 | 02:07 AM
chud298's Avatar
chud298
Default Compression ratio???
Does anybody know the compression ratio for the 1st gen 2.0 litre DOHC??? Also what combination would go better with a turbo... I'm thinking crane 16's or 18's also a compression raito of 10.5 or 12.5. This is the part list as of now:
Clevite 77 Rod Bearing Set
Clevite 77 Main Bearing Set
Carter Water Pump
Melling Oil Pump
Eagle Specialty Forged Rods
16 Eaton PT Cruiser Lash Adjusters (Lifters)
16 PT Cruiser Cam Followers (Rockers)
AEM Adjustable Cam Gears
Crane Valve Springs and Retainers
set of stainless steel valves
race balanced Crankshaft and rotating assembly
Smooth the casting, and blend the seats, full race port with reshaped ports, reshaped combustion chamber, and full port matching.
Old Sep 29, 2005 | 03:40 AM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: Compression ratio???
you want an 8:5:1 CR and crane are prolly the best 4 it ive heard the 16 but you can use 14s for turbos.....SOHC u want a 9:2:1 JE is prolly the best in that instance for pistons. Rods are a must as well.
Old Sep 29, 2005 | 12:21 PM
chud298's Avatar
chud298
ORIGINAL: highrevr/tflea
Yeah that's why I was thinking the Eagle Specialty Forged Rods.
