Power window motors are getting pretty slugish.
Old Sep 29, 2005 | 03:26 PM
zeon's Avatar
zeon
Default Power window motors are getting pretty slugish.
Is there something that I can grease or adjust to get them back moving at their usual speed...
Or are the motors just getting old?
Thank you.
Danny
Old Sep 29, 2005 | 04:48 PM
casper's Avatar
casper
Default RE: Power window motors are getting pretty slugish.
Some white lithium grease on the track and some WD-40 on the motor and arms could help. It might be the motor going though. Try lubing it and if that does not work, get a new motor.
Old Sep 30, 2005 | 12:35 PM
highrevr/tflea's Avatar
highrevr/tflea
Mine does the same thing.....not quite sure as to why , though....
Old Sep 30, 2005 | 04:26 PM
pimped_neon_RT's Avatar
pimped_neon_RT
What year is your neon mines a 98 and i think the windows move pretty dam slow to but ive only had my neon like a month, and didnt really seem to slow done. YET?
Old Sep 30, 2005 | 04:30 PM
zeon's Avatar
zeon
Mine is a 98' as well.
At first they were just slowing down when the window was like half way down/up.... but now it's slow all the way up/down, and sometimes... not all the time but often enough I pretty much have to push it down myself when it get's to about half way down.
Danny.
Old Oct 2, 2005 | 04:03 AM
RayDog26's Avatar
RayDog26
i think it has to do with this year i dunno, i also have a 98 and my motors are really slow.... drivers side goes fast if im doin it alone... both go slow no matter what if i do them together...... the passenger side is slow even if done by its self so im gonna go with needing new motors...
Old Oct 31, 2005 | 11:31 AM
tankboyuk's Avatar
tankboyuk
My 96 neon has the same problem but only with one window. it is considerably slower than the drivers side one. Has anyone removed the door panels yet? Normally on alot of cars they can be a right pain in the ****.
Old Oct 31, 2005 | 02:11 PM
RayDog26's Avatar
RayDog26
i took my door panels off many times its just two screws and clips... the clips are easy to break so expect to break some but they are cheap to replace... to remove it completely there and like 3 wires for the switches.... but you can just push the whole panel aside and have full access to every thing in the door.
Old Oct 31, 2005 | 02:20 PM
tankboyuk's Avatar
tankboyuk
cheers, i will take a look,
thanks for that
Old Nov 11, 2005 | 02:11 PM
Charles Leto's Avatar
Charles Leto
I also have a 98, mine is a 2 door, and the windows are slow, i've had problems lately with the switches being worn out, i'm sure thats part of y they are slow, if those don't help than i'm going to replace the motors and see what happens.
If any of you have noticed a lit of slop side to side in the window when its say half way down there are 2 screws in side that door to adjust that play.
