Asd relay no start problem I searched the forums already please help
Subscribe
Oct 10, 2013 | 10:10 AM
I have a 98 r/t 2.4 swap I put a new trans in drove it for about two weeks completly fone o took my girl to teach her stick she did fine except for consyant engine breakin in every gear the car died and started right back up about 6 times we parked it in the drive way an hour later I went to leave and no start the fuel pump fuse kept blowing so I replaced the fuel pump the fuse stoped blowin but still wont start I found that my ignition hot in the asd relay is being constant for some reson any ideas? And does any one no were the circuit breaker is if there is one? P.s. I replaced the pcm battery groun engine ground and crank sensors already the wire is hot even when thers no engine harness or pcm hooked up
Reply 0
Subscribe
