1995 Neon Oil Separator/PCV line issue
Old Nov 3, 2013 | 05:05 PM
reid2015's Avatar
reid2015
Cool 1995 Neon Oil Separator/PCV line issue
Hi All...Is there a mod to relocate the PCV line from its original location on the oil separator? I had to repair a crack on mine today and found after replacing the hose, it's kinked about halfway shut.
I'm thinking about relocating the PCV valve into the right hand part of the separator and running a hose from the newly relocated PCV directly into the intake. It would eliminate the kink issue and would perhaps keep oil out of the intake better, as I found oil in the bottom of the manifold on the butterfly end.
Any ideas?
