Wheel Bearing - 98 Dodge Neon
Old Nov 21, 2013 | 02:30 PM
katwebb81983's Avatar
katwebb81983
Exclamation Wheel Bearing - 98 Dodge Neon
The internet is not helping me much and honestly neither is my Haynes manual and my mechanic father lives 8 hours away so I'm suck figuring this out on my own. Any help you can offer would be greatly appreciated.
I know the front wheel bearing on the passenger side is bad. I have picked up a new bearing and hub assembly from AZ and had them pressed together.
Haynes manual says to remove the steering knuckle and everything online says that the steering knuckle and hub/bearing assembly have to be unpressed and pressed together by a shop.
Is there any way that I can remove the old hub/bearing assembly and install the new one without special tools? (I don't even have access to a bench vice.)
Thanks.
Old Nov 21, 2013 | 03:13 PM
Welcome to DF. I will move this to the Neon section so you can get some help.
