dash question
Old Dec 23, 2013 | 06:51 PM
1955effie's Avatar
1955effie
Default dash question
I just replaced the speedmeter dash assembly on my sons 99 Neon ( old one would not pick up the speedometer and somtimes the gauges won't work) .He says everything is working but now the check engine light is on . OIL was changed approx 2k miles ago new timing belt and water pump etc approx 5 k miles ago . It's running fine and has 63k miles any thoughts ? Thanks
Old Jan 3, 2014 | 01:05 AM
95neon1025's Avatar
95neon1025
What was the reasoning behind replacing it instead of just soldering the bank side of it to fix it?
Old Jan 3, 2014 | 10:52 AM
1955effie's Avatar
1955effie
Thanks for getting back to me . The gauges were not working . We tried soldering them but to not avail . So we replced the gauge assembly they are now working but the service engine light is now on and flashes . Everything is new as far as the timing belt ,water pump was also replaced while we were right there .
Old Jan 4, 2014 | 12:34 AM
95neon1025's Avatar
95neon1025
Have you tried turning the key to the on position 3 times and watching the cel light to see what the code is?
Old Feb 5, 2014 | 03:13 PM
JRTRUCKINGANDREW's Avatar
JRTRUCKINGANDREW
ok how do you solder it?
because my dash goes in and out? but mostly the speedometer really...
and if i tap my the top of my dash it will go on but sometimes wont. and when I turn off the car it keeps marking full tank, temp marks good and stays at 55 mph and 2000 rpms.?
any ideas of what this is?
