axles, transmission problem
Old Oct 14, 2005 | 01:31 AM
extremefreaks's Avatar
extremefreaks
Default axles, transmission problem
Hey I got a problem with my 95 auto dodge neon..when I started my car up and put it in reverse it sometimes it stuck and I have to force it in, also another thing when I put it on drive and when it shift gear my front driver side tire or axles stumble or kinda jerked(vibrates) for a bit and drive smoothly..So if anyone know the problem cause ..any info will be helpful
Old Oct 14, 2005 | 07:22 AM
casper's Avatar
casper
Default RE: axles, transmission problem
Well I am assuming its an ATX. CHeck your trans fluid level. If it is full have the trans serviced, flush, fill, and bands ajusted. If that does not work rebuild the tranny. Now that is assuming there are no codes relating to the trans. Check your codes.
