filling gear oil
Old May 4, 2014 | 12:23 PM
hondavtx2006's Avatar
hondavtx2006
Default filling gear oil
have a 99 neon highline five 5 speed just replaced cv shaft, where does a person refill the gear oil that drained out?
Old May 7, 2014 | 06:50 PM
sbhawaiian's Avatar
sbhawaiian
Try a cheap hand pump. If you use the heavy gear oil, I cut the pointed tip and stick a piece of clear tubing. It can get messy but it works. Fill till it comes out of the filler hole. I don't mind getting dirty but there is something about the smell of gear oil I don't like.....
Old Jun 1, 2014 | 08:19 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Drain all old fluid through drain hole, then replace drain plug. CAREFULLY remove the speed sensor, nowfill through this hole with funnel. Easier with less spill.
