1995 Neon blower bad or resistor
Old Dec 14, 2014 | 01:43 PM
moparsrule60's Avatar
moparsrule60
Default 1995 Neon blower bad or resistor
Blew the fuse on my blower motor , replaced the fuse keeps blowing everytime i turn the blower switch on. Disconnected the wiring connector to blower motor, fuse does not blow now. How can you check the motor to see if is bad I already pulled the motor out . Can I use a multimeter to check to test if motor is bad.
