cylinder head problems....need help ASAP
Old Oct 26, 2005 | 04:21 PM
crappy98's Avatar
crappy98
Default cylinder head problems....need help ASAP
the car is a 98 SOHC automatic. the problem is that the cam walking around in the head ate through the cam position sensor. my question is, how is the cam held in from moving laterally anyway? is there some way to shim it, or is the cam sensor intended on being ridden on by the cam? the car has 130k on it, and this never happened before....i need help ASAP though, i cant get to work.....thanks in advance
Old Oct 26, 2005 | 08:32 PM
casper's Avatar
casper
Default RE: cylinder head problems....need help ASAP
That does not sound good if it ate into the cam sensor. Are you sure that it is actually touching the cam?
Old Oct 29, 2005 | 08:20 AM
RadarLove's Avatar
RadarLove
The cam gear should stop it from moving towards the cam sensor. If the cam is moving around in the head, chances are the journals are shot, and the only fix is going to be a new head...
Best of luck!
