jeep Tb swap?
Old Nov 10, 2005 | 01:11 AM
95SPRTcpe's Avatar
95SPRTcpe
Default jeep Tb swap?
i heard you could swap in a jeep TB into a neon, if that would work on a 95 sohc. what year model/engine jeep would it have to come off. and is it just a simple bolt on or would i need to mod it?
Old Nov 10, 2005 | 08:33 AM
RadarLove's Avatar
RadarLove
Default RE: jeep Tb swap?
mid- to late-90's straight 6. The manual tranny TB is 55mm, the auto is 60mm.
Modding is involved. You'll have to use your butterfly shaft, which means you'll have to grind on it some for the Jeep's butterfly vlave to fit. You'll have to use the Neon's IAC, pretty sure you have to use the Neon TPS as well. One of the mounting holes has to be elongated a smidge. Dremel, patience and an hour or two worth of work. Plus you'll be better off porting the intake manifold to match...
Best of luck!
