Looking for 2.0L SOHC intake manifold.....
Old Nov 12, 2005 | 12:11 AM
Ice_Man_67's Avatar
Ice_Man_67
Default Looking for 2.0L SOHC intake manifold.....
Trying to find an intake manifole for a 2.0L SOHC..........already found one made by INDY......but wanna compare to others.
Old Nov 12, 2005 | 08:50 AM
RadarLove's Avatar
RadarLove
Default RE: Looking for 2.0L SOHC intake manifold.....
The INDY was designed specifically for a particular car and a particular application. A mostly stock 2.0L isn't it... in fact, most folks have lost power in most of the power band using it on their cars.
The intake manifold off the Magnum engine is a dual runner design, and it bolts right up to the regular SOHC head. You have to rig some sort of setup to operate the butterflies (like a window switch running off the tack wire), and then either run a 2nd gen TB or have a plate made up to run the 1st gen TB. There are also box-style setups out there, if you know where to look...
Best of luck!
Old Nov 15, 2005 | 12:46 AM
Ice_Man_67's Avatar
Ice_Man_67
i don't know where to look haha.........any help would be appreciated
Old Nov 15, 2005 | 01:59 AM
highline95jl's Avatar
highline95jl
i have a stock one, never used if you want it.
