I know I've asked this question b4 but I haven't gotten any strait answers so I figured I'd try again. Will a 215/35R18 setup fit on a 1st gen neon without hitting the spring perch on the struts? Its sad I can't answer this for myself seeing as how I work at schwabs but we don't have any 215/35R18's mounted up that I could try on for fitment. Mostly looking for answers from people who have had or been around them enough to know if its possable (with stock struts/spring perches), what kind of offset and so on.
first of all u cant fit 215 on a neon 205 is the biggest unless u want to cut **** and i put 18 on with a 35 wall and it looked higher than most trucks so i went with a 17 with a 205/40/17 and it a ruff ride
you can fit a 215/35/18 on a stock neon without ny modifications. i know because i had a set on mine for a while. but then i went with a 215/40/17 made the car sit lower then the 18
