miss after egr vacuum hose repair
Old Nov 27, 2005 | 05:04 AM
beerplease's Avatar
beerplease
Default miss after egr vacuum hose repair
I got a 95 neon dohc 5 speed , I recently had check engine light go on so I checked my odb codes and it said egr failure, so I check hoses and there was a cracked hose headin to egr, which I replaced . Car was running fine before light came on and hose repair,. but now it seems to have developed a slight miss when I'm cruising at same speed, seems fine at acceleration. Any suggestions ? I did wires last year, plugs in august .I forgot to mention , my friend had a scan tool and double checked my diagnosis before I fixed hose and in the process cleared my check engine light . I have checked my obd and no new codes have been triped,egr also hasn't triped the code since repair . Thanks
Old Mar 15, 2008 | 09:08 PM
blissm14's Avatar
blissm14
Default RE: miss after egr vacuum hose repair
does it miss at idle
