car misses no trouble code but egr suspect
Not sure about this diagnosis but here it goes. my 95 dohc 5 speed has a slight miss at acceleation and cruising. no miss at idle ,but,when I disconnect my hose leading to the egr .the car accelerates and cruises smoothly,but than the same miss occurs at Idle. I had a trouble code a month ago for the egr and when I checked it out I found the hose was broken and replaced, since then no code. I figure if the valve was bad I would trigger the code. Any body else have this expierence. Thank's
RE: car misses no trouble code but egr suspect
Thanks for the replies,the car is tuned up and new wires I also tried premium gas and tried injector cleaner,let me ask u dazzellers_95 ,why did u disconnect your egr ? trouble code, running bad or both ? also how did you disconnect it ? did you just disconnect the hose ? Now that it's disconnected how does it Idle ? when I pull my hose the car accelerates and cruises much smoother.but than I get the same type of miss at Idle. untill my check engine light comes back on I'm reluctent to change my egr because in the past my obd has really been great for trouble shooting. I know if I pull the hose eventually the code will come up. Thank's again for your input.
I'm positive I'll get a code if I disconnect the hose,I just replaced the hose 2 weeks ago because I got a code and found a crack in it.The problem now is with the hose connected I don't get a code,car ran better with the crack in the hose, without the code I'm not sure what to replace but suspect egr,but at the moment still a perfect 55 coming up
Trending Topics
ORIGINAL: beerplease
if you have done a tune-up, and injector cleaner, do try the premium gas again, and maybe think about checking the gap on the plugs? i really dont know what else to tell you, so good luck.
Thanks again for the reply's, I'm gonna do like you said and clean it, I was told by some you can clean it and some you can't, before I take mine off what did you use to clean yours ? I heard you need a small drill bit ,which I don't have handy . If you could tell what you did I what tools I'll need ,that would be great .Thanks again
