Bogging issue
Old May 25, 2019 | 03:38 AM
Heyyyjoeyyy's Avatar
Heyyyjoeyyy
Default Bogging issue
Hey guys. So I'm having an issue with my 95 neon. I had pulled the motor to replace the tranny and had some issues once I put it back in which almost all I've worked out except this. So it fires right up idles great, but anything under about %50 throttle it falls flat on its face. However anything above %50 revs right up as it should. I'd figure tps but I just wanted some input on what you guys think. It does have an r/t cam, modern proformance tuned ecu, headers an full 2 1/4 straight pipe. All egr is deleted. Also the coil, crank, an cam sensors have been obd2 jumped.
Thanks in advance!
Old May 30, 2019 | 06:31 PM
larson377's Avatar
larson377
could be an issue in your throttle body? ive seen some other cars (not neons) have issued idling because of a dirty throttle body but it still works when you give it some gas. might be worth looking into.
