which pcm
Old Dec 16, 2005 | 01:45 PM
streetbikr600's Avatar
streetbikr600
Default which pcm
couple of questions for u guys
which pcm is better af/x or mopar?
wat is the difference between the two?
will my check engine light come on if i get one of them?
Old Dec 16, 2005 | 04:03 PM
Gary Howell's Avatar
Gary Howell
Default RE: which pcm
The Check engine light will come on if you have a problem. THE AFX makes the most power, and it the best one. The AFX street makes a little bit more power than the Mopar, but for the price differences I would go with the Mopar over the AFX Street. If you ant the best, get the AFX race.
Old Dec 16, 2005 | 04:08 PM
dazzellers_95's Avatar
dazzellers_95
i'm goin with a mopar myself, i am gettin it in feb, i havent heard any complaints about it.
Old Dec 16, 2005 | 05:18 PM
casper's Avatar
casper
No, you will not have a check engine light. There is no "better" PCM, it all depends on what you have and how far you are gonna go with the motor, and how much you wanna spend.
Old Dec 16, 2005 | 07:21 PM
dazzellers_95
so, which ecu would be better for a 95 sohc 2.0l that will be runnin a hahn kit? 20g. just so i dont buy the wrong one. hehe.
Old Dec 16, 2005 | 09:36 PM
casper's Avatar
casper
They are all really good choices. There is not bad or good one, they will all work with the turbo. Goto Modernperformance.com and howellautomotive.com and check them all out. It is really a matter of how much you wanna spend, if you wanna have to run 93 octane( you can get away without it with the AFX street and Mopar, but you are gonna be stuck with 93 with the AFX race, and how much you are going to build the internals, if you are at all. I would suggest the Mopar of AFX street unless you are gonna go all out, but if it was me I would get the AFX race just because its not that much more and it won't hurt to put it on a bone stock neon.
Old Dec 17, 2005 | 03:40 PM
dazzellers_95
ORIGINAL: casper
yeah, i am planning on a full rebuild of my motor eventually. probably after this year when i get the ignition and such done, then next year the hahn 20g tubo, and then, if things go right, rebuild the top and bottom ends the right way to handle all the power and then some. i really didnt know there was different choices of ecu's. all i ever seen was the mopar performance one. i will have to do some readin i guess and see what is out there, thanks for the info, again.lol!
Old Dec 17, 2005 | 03:43 PM
dazzellers_95
after further looking on the sites you gave, all i can get is a mopar ecu. i have a 95 sohc. demmit!!
Old Dec 17, 2005 | 05:15 PM
sharps33's Avatar
sharps33
I'd like to lnow what kind of improvement you get, I have the same engine
Old Dec 17, 2005 | 05:42 PM
casper's Avatar
casper
Any performance pcm is not going to show huge gains on a stock motor. As you build the motor and bolt on different parts the performance PCM will work with them to allow more gains from them.
