Fuel Filter Replacement
Old Dec 24, 2005 | 01:03 AM
elnoyl's Avatar
elnoyl
Default Fuel Filter Replacement
I have a 95 plymouth neon sport manual 2.0 sohc. I am going to change the fuel filter. What tools do i need? where is it? Is there a specific brand of fuel filter i should buy?
Old Dec 24, 2005 | 03:24 AM
red91RT's Avatar
red91RT
Default RE: Fuel Filter Replacement
if they have it in stock and it's a good price, I always like BOSCH stuff--except for their sparkplugs.
It's on the passenger side, behind axle, inside fuel tank. REmove the cover plate--three screws, need a wrench and couple short sockets--I think they were 10 mm if I remember right--maybe even smaller. Then you twist the lock plate counter-clockwise and the whole assembly should come out (more or less). I've tried doing this in a parking lot with out jacking it up and I recall that it was a little hard to pull the whole thing out because the float level, etc. means you need a little angle under the tank to get it out. So. . . give yourself some room.
If you don't have the tools just go get a little $50 Craftsmen metric socket wrench set and that should get it done for you.
Luck.
Old Dec 25, 2005 | 04:43 AM
RadarLove's Avatar
RadarLove
What?!?
The filter is mounted underneath a panel just forward of the passenger side rear wheel. There is no dropping of the tank. There is no removing of the fuel pump. It's a couple of bolts and a couple of fittings. You can do it with the car jacked up without removing the wheel, but removing it makes the job a little easier.
Best of luck!
Old Dec 26, 2005 | 02:19 PM
dazzellers_95's Avatar
dazzellers_95
ORIGINAL: RadarLove
What?!?
Best of luck!
its a little cylinder thing mounted on the frame just like he said^^^
just watch out for the plastic clips that hold the hoses on the filter.
any advise for those btw??
Old Jan 13, 2006 | 02:53 AM
red91RT's Avatar
red91RT
doh--just reading old stuff. Read "filter" thought "pump". Duh. (you don't have to "drop" the tank for the pump either, but it you do have to twist the pump/sending unit a little at an angle to get it out. . . should you ever have to do that job too.)
Old Jan 15, 2006 | 08:38 AM
Ramrat's Avatar
Ramrat
I beleave it was a 10mm socet to get the cover off. i used a x-tention for the one bolt (you'll see it) and left the wheel on, took me a whole lot of cursing to figure out the line clips though, just push the line forward and push the clip together and pull whell holding the clip tight. took me about 10-15 mins for the job.
Old Jan 17, 2006 | 03:18 AM
neon1985's Avatar
neon1985
yeah i just did my pump it sucks............................................. .........................
