Codes
RE: Codes
P0351-Ignition Coil A Primary/Secondary Circuit Malfunction
P0352-Ignition Coil B Primary/Secondary Circuit Malfunction
Both of those codes refer to a problem within the Ignition coil, first check all connections, the wires going into back of it. if everything is ok there, try replacing the Ignition Coil (MSD or Dealer, whichever you prefer)
RE: Codes
ORIGINAL: Charles Leto
