what do i have?
Old Dec 29, 2005 | 05:08 AM
NonToxic's Avatar
NonToxic
Default what do i have?
can someone tell me a site where i can find out how to put on a SRI on a 95 dodge neon
Old Dec 29, 2005 | 05:09 AM
NonToxic's Avatar
NonToxic
Default RE: what do i have?
1 more thing... how do you know if you have a dohc or sohc?
idk how to tell when i look at my engine.
Old Dec 29, 2005 | 05:42 AM
highline95jl's Avatar
highline95jl
Its either gonna say on the valve cover or look in your manua. More likely than not since you have a 95 its gonna be a SOHC, but dont fret, the 2.0 SOHC is a kick *** motor for this class of car.
Old Dec 29, 2005 | 05:44 AM
highline95jl
Oh and to find out where to put an SRI on just go to this lovely site. *********
*EDIT* Please do not link competing forums on DF.
Old Dec 29, 2005 | 11:03 AM
RadarLove's Avatar
RadarLove
If the 8th digit on your VIN is a "C", it's a SOHC. If it's a "Y", it's a DOHC.
Haynes manuals are handy. You remove the stock air intake unit, and the POS... er, I mean "SRI"... replaces it. It's a couple of bolts, clamps, and about a half hours worth of work.
Best of luck!
Old Dec 29, 2005 | 01:26 PM
dazzellers_95's Avatar
dazzellers_95
"sri?" ==short ram intake??
dohc heads are about 10" in width, mebe even 12, and the sohc is about 8". also, i think the dohc intake mani is aluminum? correct me if i am wrong, cause i have a sohc and it is plastic. not too familliar with dohc's.
Old Dec 29, 2005 | 05:50 PM
NeonKnight's Avatar
NeonKnight
DOHC has 2 cam gears, SOHC has 1, i had to explain this to a guy at a junk yard, he said he had a head for my neon, when i got there it was a sohc, i had to pull the timing belt cover off to show him[8D] thats the easiest way to tell for sure i suppose
Old Dec 30, 2005 | 01:50 AM
casper's Avatar
casper
ORIGINAL: dazzellers_95
I guess, never heard of an SRI either.
Old Dec 30, 2005 | 02:03 AM
whyte69's Avatar
whyte69
why you would go with an SRI instead of a CAI I wouldn't know. An SRI would draw slightly cooler air than your current intake brings in. A true CAI would draw in close to the same temperature air that his passing over the hood of your car. Colder air means denser oxygen molecules, meaning better combustion. I wouldn't have gone with an SRI, personally.
To answer your question, all that needs be done to install an SRI is to remove your stock intake and bolt on the new SRI. It should be pretty evident once you've got the intake off.
