95 Neon Engine Swap NEED HELP!
Old Jan 4, 2006 | 08:00 PM
95NeonJS's Avatar
95NeonJS
Default 95 Neon Engine Swap NEED HELP!
So I bent a couple valves on my neon when my timing belt skipped 1,000,000 teeth. I bought a new engine: 95 SOHC but it's got an AT and I am wondering if I can simply bolt on my MT to the engine? Someone mentioned that I might need to have the crank drilled to put a bering in or something... but they weren't sure if it was necessary on the neon
Old Jan 4, 2006 | 08:05 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: 95 Neon Engine Swap NEED HELP!
no it should bolt on fine...
Old Jan 4, 2006 | 10:50 PM
dazzellers_95's Avatar
dazzellers_95
trany will bolt on perfectly, and will work also if you have the mtx engine ecu(computer) which you should have since you r car was a mtx in the 1st place right.
easy swap. good luck.
Old Jan 5, 2006 | 04:32 PM
RadarLove's Avatar
RadarLove
Putting in a new clutch as well by chance?
The 95's had a conventional (non-modular) clutch setup. The '96-up Neons built in the U.S. had a modular clutch that bolted to the same flexplate that is used for the ATX. The PT Cruiser modular clutch (non-turbo) is cheaper and more reliable than any of the Neon clutches and bolts right in (same tranny). You would need a dust shield from a modular-design tranny (try www.deyemeracing.com or your local salvage yard), and the bolts to attach it in back (dealer item). Don't forget a new throw-out bearing and the correct fluid (Mopar Manual Transaxle Lubricant) while you're at it.
Best of luck!
