Weird light on dash?!?
Old Jan 6, 2006 | 05:31 AM
pimpberetta's Avatar
pimpberetta
Default Weird light on dash?!?
The parking brake light on the dash illuminates everyonce in awhile. No my parking brake is not on, yes i even checked myself lol. Its seems only when i get on the gas a little bit and maybe 1/5 times it'll do that, it will illuminate itself. What could this mean. I notice beside the "P" theres a exlacmation mark. What does that have to with, parking brake or somethign else?
thanks in advance, sean
Old Jan 6, 2006 | 04:59 PM
SilverEmperor's Avatar
SilverEmperor
Default RE: Weird light on dash?!?
Check ur brake fluid level, im not sure if it works in neons too, but usually when that light comes on by itself, it means ur low on brake fluid
Old Jan 6, 2006 | 05:06 PM
95NeonJS's Avatar
95NeonJS
Yeah that should be the problem. The brake fluid might be low, and when you put the pedal to the metal the fluid in the container shifts toward the back and so the reader shows that it is empty. Just fill it up a bit and you should be good!
Old Jan 6, 2006 | 05:18 PM
pimpberetta
Alright, i checked and it is a tad low, i will fill her up and see what happens!
Thanks alot
Old Jan 6, 2006 | 10:39 PM
casper's Avatar
casper
ORIGINAL: 95NeonJS
thats it
Old Jan 7, 2006 | 08:48 PM
mr340's Avatar
mr340
Muscle Car Moderator
Brake fluid in a sealed system does not evaporate. If the fluid level in the master is low, either it's time ofr new brakes or you have a leak. I would check the brakes before just adding fluid, I'd hate to find out the hard way....
