New Plugs
Old Jan 19, 2006 | 08:17 PM
highline95jl's Avatar
highline95jl
Default New Plugs
Ok 3 questions
First can I have a set of directions for replacing my plugs and wires.
Second wich brand of plugs and wires are the best.
Third, if I am having a problem with my valve cover gaskett, will that be an issure when replacing the plugs and wires.
Old Jan 20, 2006 | 01:26 AM
whyte69's Avatar
whyte69
Default RE: New Plugs
I found a pretty good tutorial Here
Secondly: NGK plugs are what's recommended by Dodge. It should say under your hood somewhere, either near the top of the engine bay, towards the front grille, or along the front lip of the hood. It'll tell you the style that it came with and the gap that you should use for stock applications. As for the wires, Crane have been highly recommended by a few people because they've got the lowest resistance. MSD is a close second.
Thirdly: I can't tell you a whole lot about the valve cover gasket. I'll leave that for someone like Gary or someone who knows what they're talking about.
Old Jan 20, 2006 | 09:59 PM
highrevr/tflea's Avatar
highrevr/tflea
ngk....
Old Jan 20, 2006 | 11:22 PM
notallhere's Avatar
notallhere
Dont the numbers indacate the heat range, how hot ya want the spark?
as for the wires getting crossed thats not an isue just pull one plug at a time
And make sure the block is cold before ya start, nothing worse than a stripped plug thread.
Old Jan 30, 2006 | 06:53 PM
neon1985's Avatar
neon1985
Valve cover gasket has absolutly nothing to do with changing your plugs are wires(if there isn't a problem with the gasket leave it alone you dont need to change it to change your plugs and wires)
Old Jan 31, 2006 | 12:33 AM
casper's Avatar
casper
Its pretty straight forward. Pull a plug and wire, put in new plug and wire, repeat 4 times. NKG or champions are good plugs.
