Turbo compatibility
Old Jan 24, 2006 | 03:04 AM
SCCA B8's Avatar
SCCA B8
Default Turbo compatibility
hey-
I am looking at the chill factory stage 2 kit and was just wondering how much more modification than the kit i would need to make it safe to run the car, i already have larger injectors. Also, will this mean the iceman has to be removed or relocated? I still plan on passing emissions and driving this on the street occasionally. This is for a 1997 sohc. Thanks for your help.
Old Jan 24, 2006 | 09:54 PM
casper's Avatar
casper
Default RE: Turbo compatibility
If you get the kit, it comes with everything you need to run it on the car. I believe the stage 2 is safe to run on fully stock internals, I know it says it is on the website.
Old Jan 25, 2006 | 03:57 AM
highline95jl's Avatar
highline95jl
What about a stage 3?
Old Jan 25, 2006 | 11:55 AM
tooslow's Avatar
tooslow
I think the stage3 is basically a stage 2 but you also get all the parts too built our motor
Old Jan 25, 2006 | 05:08 PM
SCCA B8's Avatar
SCCA B8
cool, so the iceman would most likely have to be removed i presume...
Old Jan 25, 2006 | 08:44 PM
casper's Avatar
casper
I believe that stage 3 is still compatible with a stock motor. I would not run it on a high milage motor, but under 150,000 miles you should be fine for a while. There is no way to use an iceman on a turbo 1st gen other than choppin and custom fitting it, you are better off with some piping and a K&N filter.
