Just wonderin......
Old Jan 29, 2006 | 02:07 AM
Jeanette656's Avatar
Jeanette656
Default Just wonderin......
This is the first dodge ive owned (96 neon sport 2.0) Ive heard that neons are notorious for head gaskets, Is there a certin kind of oil and antifreeze that might help prevent this? Also, which plugs and wires work best?
Old Jan 29, 2006 | 04:43 AM
highline95jl's Avatar
highline95jl
Default RE: Just wonderin......
Copper plugs and wires are the best on the Neon. NKG is the top recomended brand. As far as preventing the head gasket from blowing the best thing you can do is replace it now before it blows. Its gonna go sooner or later weather you change your oil type or not.
Old Jan 31, 2006 | 12:44 AM
casper's Avatar
casper
The only head gaskets that had problems were the 95- 97 I believe and most likely by now yours has been done. There should be a little tab on the gasket sticking out of the head with "MLS" on it. That means you have the good head gasket. There is no reason to change it if you are not having any problems.
Old Feb 2, 2006 | 07:19 PM
neon1985's Avatar
neon1985
by any chance does anyone know where to get a mls gasket from or do i just ask for a late head gasket at autozone?
Old Feb 3, 2006 | 07:37 PM
casper's Avatar
casper
Any gasket that you are gonna get is the MLS. Any parts store should have it or be able to order it.
