carbon fiber
RE: carbon fiber
I doubt there is a TT eclipse out there that does not have some major work done to it. The Stealth, 3000GT, and 300zx use a TT set-up, but they are all 6 cyl. It is possible, just pointless and not gonna last that long. A turbo is driven by the exhaust gas, 2 cyl will not have enough flow to turn a big turbo and if you use a smaller one it is gonna be hard to keep cool and is gonna burn your oil.
RE: carbon fiber
yeah a twin turbo isnt a great idea for this build i would recomend if your going to want serious hp output rebuild the bottom end (pistons, rods, and all that jazz,) and do some other headwork and then run a higher stage turbo and that will still give you a lot of power.
RE: carbon fiber
correct me if im wrong but the job of the intercooler is to keep the turbo cool? or are we talking about diff. things, more then likley going to go w a single 20g kit though i dont think my guy will have the time to do the manafold and if its going to be kinda ify if it would be dependable why waste the $ and fry my motor
RE: carbon fiber
if you want an easy task, just swap the srt4 2.4l turbo engine into your neon, and then take the money that you would use for the buildup of a normal 2.4l engine and goto stage 3 on the srt engine, you will be more impressed with tat outcome and save alot of money in the process. but, if you are like me, you want to keep it the same motor that was in the neon to begin with.
you can use a 20g turbo on a sohc neon engine 2.0l and with the internals done, you will have a real nice street car. add some n2o to that beast, and it will scare you silly.
RE: carbon fiber
ORIGINAL: hndawht
alright makes sence to me, heres one for you casper whats the deal w the srt rods and pistons? since i cannt seem to find a deffinate yes or no would it be benneficial to use aftermarket rods and pistons or are is the srt combo good for how much hp?
