Quikpipe Cold Air Intake
Old Feb 19, 2006 | 03:45 PM
honda slayer's Avatar
honda slayer
Default Quikpipe Cold Air Intake
I was wondering if anyone could tell me which Cold Air Intake is better for my 1995 Dodge Neon SOHC 4dr Base Sedan with Automatic tranny. neons.org says the Quikpipe is better for Auto's and doesn't need to have the battery relocated. I was going to get the Iceman and deal with the battery relocation, but Modern Performance has discontinued it, and the Quikpipe is supposed to be just about as good as a shortened Iceman. And if I sould get the Quikpipe, who sells them? I've checked Modern Performance and Howell Automotive and found nothing. I can't even find a Quikpipe website. Thanks in advance.
Old Feb 19, 2006 | 05:15 PM
highline95jl's Avatar
highline95jl
Default RE: Quikpipe Cold Air Intake
Just buy a Cheapo ebay intake. Its all just a metal pipe man.
Old Feb 19, 2006 | 08:09 PM
casper's Avatar
casper
ORIGINAL: highline95jl
Thats not true, most of those ebay intakes are short rams grabbing hot air from the engine compartment. The AEM is good too, or you can pick up an iceman if you look on ebay there is usually someone selling one.
Old Feb 19, 2006 | 08:58 PM
notallhere's Avatar
notallhere
http://icemanracing.com/ this is were i found one has battery box and all you need.
Old Feb 20, 2006 | 01:07 PM
RadarLove's Avatar
RadarLove
It's not really battery relocation with the Iceman, just a new battery tray that moves the battery enough for the Iceman to fit, and it looks stock when done. If you want great performance with a nice, clean look, then go with the Iceman. If you want the same performance as the Iceman for a tenth of the cost and a little elbow grease, do your own with a mid-90's Dodge 3.0L intake tube and your own filter.
Best of luck!
