Injectors
Old Feb 23, 2006 | 06:15 PM
thefamilyguy209's Avatar
thefamilyguy209
Default Injectors
Does anyone know what the size of a stock 99 dohc injector is? and whats the next step up for a turbo putting 25 hp? What brand is the best. Thanks all
Old Feb 24, 2006 | 01:18 AM
casper's Avatar
casper
Default RE: Injectors
What turbo are you using that only gonna give you 25HP? Don't quote me, but a chill factory kit without an intercooler is suposed to be around a 60-70 HP gain on a stock motor. If thats all the hp you are looking at the stock injectors are just fine.
Old Feb 24, 2006 | 01:44 PM
thefamilyguy209
Sorry I left out a zero What i meant to say is Im shooting for 250 hp
Old Feb 24, 2006 | 03:04 PM
95NeonJS's Avatar
95NeonJS
The turbo's gonna push you to 250HP? So you got a kit to give you 100HP? About the injectors, remember that bumping up the injectors also yields the possibility of needing a better fuel pump too! If I were you, since I can't find the lbs/hr anywhere. Try running down to a dealership or calling their parts department...
Old Feb 24, 2006 | 04:23 PM
thefamilyguy209
I will do that...yes i am putting together a custom kit. Srt turbo custom piping 3 inch exhaust 60mm throttle body mega squirt fuel control and greddy boost control. Shooting for 250. we shall see how long before I blow the engine. In the mean time im building a 2.2 stroker that will handle 350hp
Old Feb 26, 2006 | 01:49 PM
RadarLove's Avatar
RadarLove
Stock ones are 19 lb, and the ones on a Dodge 2.4L (or Mustangs) are 24 lb. With Megasquirt running the show (I'm assuming fuel and spark control?), you should have no problems going to the larger injectors where most of the rrfpr-on-stock-pcm guys have trouble at idle. 250 HP on the stock internals isn't out of the question, but you might consider doubling up on the head gasket for a little lower compression. With forged internals, 350 HP isn't going to be a problem for anything on the engine, just the clutch, axles...
Best of luck!
