i need new clutch. usa or mex?
Old 12-24-2006, 09:46 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
Default RE: i need new clutch. usa or mex?
which bolts are different?????
as far as i can remember i thought i used the same ones a while back when i did the clutch in my old car
Old 12-24-2006, 04:07 PM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: xdeathwishx
any idea who sells those bolts??
Dealer.
ORIGINAL: spudsterier
The modular and non-modular clutch bolts are different lengths.
Old 12-24-2006, 05:14 PM
spudsterier
you still havent explained which bolts though....the ones that hold the clutch assembly to the flywheel????....
Old 12-24-2006, 07:15 PM
xdeathwishx's Avatar
xdeathwishx
xdeathwishx is offline
Ok, im just going to go back there and get the right parts because i dont feel like dealing with the stealership.
Old 12-24-2006, 09:44 PM
das2123's Avatar
das2123
das2123 is offline
Yes.
Old 12-24-2006, 11:00 PM
spudsterier
im gonna have to check my bucket-o-bolts and see how different they are[&:]
Old 12-24-2006, 11:27 PM
JDC420's Avatar
JDC420
JDC420 is offline
What exactly is a modular clutch, and how is it different then a normal clutch?
Old 12-24-2006, 11:49 PM
spudsterier
in a modular clutch, the backing plate, clutch disc, and pressure plate are all one unit
in a non-modular or regular clutch, all the components are separate...and can be replaced individually...
modulars are more expensive because you have to buy the whole assembly
Old 12-25-2006, 12:35 AM
JDC420's Avatar
JDC420
JDC420 is offline
Interesting, thanks for the explanation!
Old 12-25-2006, 02:43 PM
das2123's Avatar
das2123
das2123 is offline
Just the length is different.
Quick Reply: i need new clutch. usa or mex?
