New to neon and question...
Old Mar 1, 2006 | 02:46 PM
neon1985's Avatar
neon1985
Default RE: New to neon and question...
yeah i agree with road runner but i still believe the sohc lacks top end power.
Old Mar 1, 2006 | 03:06 PM
spudsterier's Avatar
spudsterier
first off, it does have a diff. pcm, i dont have enough room in the signature to write any more, next off 135 was what a was running when along side of the srt-4, i also have a program on my lap top that plugs into the obd-2 port under the dash. it allows you to monitor various sensors and readings from your car, such as rpm's, speed sensor, and others. it also has a dyno program, and a track timer for 1/4 mile. road conditions have a factor, tires, drivers, all cars were manuals. and many other factors that can alter an outcome. i also took my cluster apart and remover the needle stopper just past 120. ive had the needle all the way to the tens digit in the odometer before the rev limiter kicked in. last time a had a camera in the car i got a pic of the needle sitting on the stopper and the car kept goin. if i can get my scanner working i will post it.
Old Mar 2, 2006 | 12:03 AM
metalkid88's Avatar
metalkid88
ORIGINAL: spudsterier
my car has the dohc and it doesnt have very much done to it, but it was able to keep up with this subaru wrx that runs around town and an srt-4 that a buddy has. the dohc has a better top end then the sohc does. the sohc does real good til about 90mph then starts to take more time to go faster. the dohc just keeps on goin til about 125, then takes more time. when i was racing the srt-4 we were able to hit 135. then the rev limiter kicked in. scared the hell outa my wife.(and me) i dont plan on doin that again for a while, atleast down that road.
ive got over 10 grand in my neon and it still cant touch srt-4's
Old Mar 2, 2006 | 03:02 AM
spudsterier
if you put 10 grand into your car and cant touch an srt-4 then there is sumthing wrong with your car. unless that 10 grand is mostly visual then performance. if there is 10 grand in the motor then it would be deffinetly be able to smoke an srt-4
Old Mar 2, 2006 | 03:43 AM
highline95jl's Avatar
highline95jl
Cause you beat WRX's so you have room to talk.
Old Mar 2, 2006 | 06:22 AM
spudsterier
no just think of it this way, if a tubo kit is 3000.00 and a crate motor is 1900.00 and cams 400.00 thats just 5300.00. and you would say that wouldnt be able to beat an srt-4? what about 10 grand?
Old Mar 2, 2006 | 09:35 AM
spudsterier
wait til this afternoon and i will try to post a pic of sumthing that you might think is interresting.
Old Mar 2, 2006 | 09:44 AM
metalkid88's Avatar
metalkid88
a lot is looks body kit, rims, tires, system,lights,ground effects, racing seats, and other stuff like but i also have a full suspension upgrade(lowering springs, 8 way adjustable struts, lower and uper control arms, and sway bars) full exhaust, cams, stage 2 clutch, underdrive pulley, intake, short shifter... i think i got everything
and still doesnt come close to touching an srt4
Old Mar 2, 2006 | 03:36 PM
spudsterier
well maybe that is where your problem is. with the added weight from the system, the rims, and the other stuff, its going to slow you down a bit. is your car a sohc? that might be the problem too...or driver?
Old Mar 2, 2006 | 11:52 PM
spudsterier
check out the pics in my post.
