low gas milage
Old Feb 28, 2006 | 01:04 AM
spudsterier's Avatar
spudsterier
Default low gas milage
my neon just pushed over 116,00 miles and is now only getting 21mpg on a good day. anyone know how to get better milage.
Old Feb 28, 2006 | 02:14 AM
whyte69's Avatar
whyte69
Default RE: low gas milage
it's as simple as a basic tune-up, just in time for spring. Replace your spark plugs and wires (NGK spark plugs, or Champions. And MSD, Crane, or comparable wires). Replace your air filter (stock paper is fine, or you can upgrade to the performance K&N for a bit more). Run a bottle of fuel injector cleaner through your tank for a tank or two (LOTS to choose from, I prefer STP because it's a name I trust). Keep your tires inflated to spec which should be about 35 psi. Check all fluids especially your oil and tranny fluid. That should get you started and should up your MPG a few notches. I wouldn't expect too much more out of the car unless you're driving a lot of highway miles. The highest I've seen on these boards is 32 MPG and that's 90% highway. Let us know how these tips work for you.
Old Feb 28, 2006 | 02:54 AM
pimpberetta's Avatar
pimpberetta
I find it weird how highest you heard was 32, personally, I can haul in over 35 mpg each tank consistently, thats like 80 city, 20% highway. I dunno, a freak show car? I think on highway it comes to around 40.
