CODES!?!?!?!?
Old Mar 15, 2006 | 12:50 AM
lilrican826's Avatar
lilrican826
Default CODES!?!?!?!?
i tried pulling codes but i dont really kno how you count how many times the engine light comes on?...if thats the case it came on and paused like this 1 pause 2 pause 5 pause 1 pause 5 pause 5 pause.....anybody kno wat that mean?
Old Mar 15, 2006 | 03:31 AM
FuzzRacer's Avatar
FuzzRacer
Default RE: CODES!?!?!?!?
Here is how you count them, your CEL will blink a certain amount of times in a row then it will give a short pause and blink again to give you the next number example: blink blink blink pause blink blink is coded as 32 if you have any other numbers coming up it will pause after that code as well so 2 codes in a row would look like: blink blink blink pause blink blink pause pause blink blink pause blink the first code is 32 and the second code is 21. when the 5 blink pause 5 blink (55) comes up means that there are no more codes coming in your case you got a code 12 which means at some point during the last 50 cycles that the you disconnected the battery and the no more codes coming 55
Old Mar 15, 2006 | 04:07 AM
lilrican826
wat about the 51?
Old Mar 15, 2006 | 04:39 AM
FuzzRacer's Avatar
FuzzRacer
code 51 means that your fuel system is running lean copy and paste this link to your browser and you will find all of the codes for you neon
https://dodgeforum.com/m_63384/tm.htm if you have anymore questions just let me know and i will try to help you Good Luck
Old Mar 15, 2006 | 04:42 AM
lilrican826
oh alright thanx i just now reseted my computer and now my car IDLES at 4 rpms in neutral and park for sum reason......and its like i have no breaks at all....any clue?
Old Mar 15, 2006 | 04:56 AM
FuzzRacer's Avatar
FuzzRacer
check to see if you throttle is stuck open sometimes things can find there way into the throttle body and cause it to remain open, happen to me once in traffic, luckly I was slowed down enough for it not to make a diff but try checking that out
