Dodge to Plymouth
Old Mar 13, 2006 | 04:52 AM
NeonSpeed's Avatar
NeonSpeed
Default Dodge to Plymouth
I dont wanna sound to noobish about all this but I was searching for Intakes on ptuning.com and they only had intakes for the 2000-2003 Plymouth models and under dodge they had 95 models which is the year I have but mine is a plymouth.... Will it still work if I was to buy the dodge style intake.
Old Mar 13, 2006 | 05:11 AM
highline95jl's Avatar
highline95jl
Default RE: Dodge to Plymouth
the only difference between yours and the dodge is the badge, your good to go if you buy dodge stuff.
Old Mar 13, 2006 | 07:47 AM
71RoadRunner's Avatar
71RoadRunner
That's right. All you need to do is make sure you get one for your exact engine and transmission combo.
Old Mar 13, 2006 | 11:22 PM
Ramrat's Avatar
Ramrat
my sedan is a 96 dodge and my coupe is a 96 plymouth and the only dif is the number of doors ( the plymouth has a dodge hood ) so you're golden bro
Old Mar 14, 2006 | 02:21 AM
NeonSpeed's Avatar
NeonSpeed
Another question.. I have a 2.0 with 16 Valve.. How do I find out whether or not it is SOHC or DOHC.? It was a hand me down so I dont know much about it..
Old Mar 14, 2006 | 02:53 AM
71RoadRunner
The easiest way is to pop the hood and look at it, the SOHC has a black plastic intake manifold and the DOHC has a bare aluminum intake manifold.
This is a SOHC:
[IMG]local://upfiles/193/4619E67A4A484F9E97FCCBBB3879CC77.jpg[/IMG]
This is a DOHC:
[IMG]local://upfiles/193/221D0038FBE644458CFB32071F08CCA2.jpg[/IMG]
Old Mar 14, 2006 | 05:02 AM
booboo's Avatar
booboo
after readin this and lookin at the pics i gots aquestion for you roadrunner or anyone else i have a SOHC 96 neon looks very similar to the pic but has the same valve cover as that DOHC does in the pic the coil pack is mounted like the one with a dOHC and my car doesnt have the "snorkle" comin up beside the intake piping also mu intake piping has some sort of air sensor on it im sure it pulls the temp of the air but it also has several locations for vaccum lines also just curious as to what these differences are and if u can be any help
Old Mar 14, 2006 | 11:48 PM
NeonSpeed's Avatar
NeonSpeed
Thanks for the help I defintly have the SOHC... What happens if you take the intake manifold off?
Old Mar 15, 2006 | 02:07 AM
RadarLove's Avatar
RadarLove
booboo - the SOHC shown in the pic is a '95, which has a different valve cover, different PCV setup, different oil cap location, and different coilpack mount than all the 1996-2005 SOHC's. The DOHC valve cover will not physically fit on a SOHC head. If you don't have a snorkel poking up, it was probably removed intentionally or simply fell off. The hole for it should still be there in the stock air box. The intake piping shouldn't have any sensor on it, not stock anyways. The air temp sensor is located on the intake manifold, a combined unit with the MAP sensor (which HAS to be on the intake mani...) for the '96 models (seperate sensors on 95's). The only hose coming off the intake piping should be part of the PCV system. The vacuum lines will be coming off the intake manifold as well.
My '95 SOHC came with an aluminum intake manifold from the factory. Painted flat black though. Still have it, in the back seat...
NeonSpeed - your car will not run without the intake manifold on. Not sure exactly what you are asking...
Old Mar 15, 2006 | 04:04 AM
NeonSpeed's Avatar
NeonSpeed
Yea I was thinking about something else but typed intake manifold... hehehe
