How to time DOHC motor?
Old Mar 19, 2006 | 05:36 PM
coocoobird's Avatar
coocoobird
Default How to time DOHC motor?
Hey everyone,
Me again! i have a dohc motor and on my two cam gears there are two marks on each sprocket. Do i have to just make a straight line across them or do the lobes of the cams need to be a certain way on each cam? A few mechanics told me to just line them up but its deffinatly outta time like that. So i was wondering if it would be easier to just look at the lobes of the cam and set each one a certain way. Any help would be greatful.
Old Mar 19, 2006 | 05:44 PM
burpleneon's Avatar
burpleneon
Default RE: How to time DOHC motor?
i thought the lil lines needed to be at 12:00 postion and the arrow on the crank?
Old Mar 19, 2006 | 05:46 PM
coocoobird's Avatar
coocoobird
ORIGINAL: burpleneon
oh great lol another option. I never heard about the 12 o clock position. Can anyone confirm?
Old Mar 19, 2006 | 05:55 PM
spudsterier's Avatar
spudsterier
the cam lines need to be across from eachother..intake at 9:00 and exhaust at 3:00.....do you have the crank figured out???
Old Mar 19, 2006 | 06:03 PM
coocoobird's Avatar
coocoobird
ORIGINAL: spudsterier
Not exactly sure what you mean by that. I just lined up the crank arrow with the other. Im new at this. Never done this stuff before .. so be gentle.[8D]
Old Mar 19, 2006 | 06:11 PM
spudsterier
if you just line up the crank arrows then you are going to have a huge problem when you put it back together...it wont start right and will run like crap(when it does)....you need to remove the #1 sparkplug, stick a small dollrod or sumthing equivelent down the whole and onto the piston..then rotate the crank until the rod lifts up as high as it can...that will bring you to top dead center...then lighn up the arrow from there, it should be close by then...then MOVE THE CRANK COUNTERCLOCKWISE 1 TOOTH, NO MORE..because when you put the tensioner on it will move the crank about to where it needs to be
Old Mar 19, 2006 | 06:25 PM
coocoobird's Avatar
coocoobird
ok so i get the #1 piston at TDC then move back couter clockwise 1 tooth ,then set the cams to intake at 9:00 and exhaust at 3:00
slap the belt on to pull the arrows in line. And that should be it correct?
Old Mar 19, 2006 | 06:29 PM
spudsterier
yeah, the cams wont move when you put the belt on and the crank should pull to about right where it needs to go, but you dont need to worry about it if it doesnt lign up exactly, unless its like 1 tooth off
Old Mar 19, 2006 | 06:38 PM
coocoobird's Avatar
coocoobird
ok this may be stupid but the intake cam is on the front of the engine and the exhaust in back right?
Old Mar 19, 2006 | 07:01 PM
coocoobird's Avatar
coocoobird
Also after i set the crank to TDC its pretty safe to turn the cams clockwise till they are in position without worrying about raming the valves into the pistons?
