Manual transmisson noise
Old Mar 19, 2006 | 11:18 PM
neonfrk132's Avatar
neonfrk132
Default Manual transmisson noise
1997 plymouth neon SOHC 149,000k 5-speed manual, im hereing a scruffling noise in the tranny in neutral, also through the gears mostly at lower rpm, but tends to go away win car warms up. shifter isn't as easy to shift mostly down shifting back to first gear.
Old Mar 19, 2006 | 11:24 PM
highline95jl's Avatar
highline95jl
Default RE: Manual transmisson noise
Check your cables.
Old Mar 20, 2006 | 03:13 PM
neonsareslowaspiss's Avatar
neonsareslowaspiss
highline.. anyone that has a brain can tell that you have no idea what youre talking about 98.4% of the time.
Old Mar 20, 2006 | 06:45 PM
highline95jl
The reason I say shifter cables is because if they are loost or disconnected the shifter will become hard to use, almost even impossible to sift if they are disconnected, they will even cause alot of racked, and possible buring if they are disconnected.
Old Mar 20, 2006 | 06:46 PM
pimpberetta's Avatar
pimpberetta
lol.
I think the answer to your problem is your release bearing as some have said. I have the same problem myself.
Sean, hope that helps
