where can i find
Old Mar 26, 2006 | 06:59 PM
burpleneon's Avatar
burpleneon
Default where can i find
were can i find performance valve springs that wont break my wallet?
Old Mar 26, 2006 | 10:16 PM
gutted's Avatar
gutted
Default RE: where can i find
You can use Magnum valve springs, available from various online vendors or your local friendly Dodge dealer.
Old Mar 27, 2006 | 02:45 AM
FuzzRacer's Avatar
FuzzRacer
http://www.modernperformance.com/dcx...ne-trans.shtml
Scroll down to the near bottom of the page and you will see some valves,
For the Dohc a set of 16 will cost you $99.99 and for the Sohc a set of 16 will cost you $139.99 but thats with out the retainers, hope that helped some
Old Mar 28, 2006 | 02:06 PM
RadarLove's Avatar
RadarLove
Uh.... if you're SOHC... screw that!... Magnum springs will only run you $50 or so for the set of 16 from a discount dealer like www.fsautomall.com or www.dodgeparts.com (plus shipping). The part number for the set is 04884058AA, much cheaper than ordering individually. You can use the retainers from your car, or whatever SOHC Neon you want... Titaium retainers are most definitely not needed... The Magnum valvesprings have held up the best with even the biggest cam (the 004 at least), revving to 8k rpm on a regular basis.
If you're DOHC, then by all means go with the Crane offerings, that's all you've got...
Best of luck!
Old Mar 29, 2006 | 08:02 PM
burpleneon's Avatar
burpleneon
ill call the dodge dudes and see what they can do
Old Mar 29, 2006 | 08:15 PM
FuzzRacer's Avatar
FuzzRacer
Well I guess that's all I have then. why cant the magnums go with the Dohc, are there alternatives for the Dohc motors?
Old Mar 29, 2006 | 08:16 PM
FuzzRacer's Avatar
FuzzRacer
Old Mar 30, 2006 | 12:43 PM
RadarLove's Avatar
RadarLove
Completely different spring size, won't physically fit. DOHC's have tons of lift available to them. The best SOHC's can hope for is 0.400", and that's with a reduced radius base circle cam and lash caps...
Old Apr 3, 2006 | 01:13 AM
FuzzRacer's Avatar
FuzzRacer
Well that would explain it, thanks for the info.
