blowing brake light fuse
Old Mar 26, 2006 | 11:27 PM
spudsterier's Avatar
spudsterier
Default blowing brake light fuse
my headlights work the side markers work and so do the taillights and running lights.....but as soon as you push the brake pedal the stop lamp fuse in the engine compartment blows...and the turn signals dont work....any ideas what the problem could be???
Old Mar 27, 2006 | 02:35 AM
FuzzRacer's Avatar
FuzzRacer
Default RE: blowing brake light fuse
I had this problem when I was putting in red leds for my clear tails, except my one turn signal would go slow, and the other one would go nuts, then stepping on the brake blew the fuse. The guy at advanced auto told me that it was a wattage issue, so I bought some different ones and it still happend. so then I just called the shop that fixes my car and he told me that it could be that the harness for one of the bulbs can't handle the the led So I had to either upgrade the harness or just stick with the red ones that go orange in 2 days. have you changed the bulbs recently? could be that if not then maybe its something with wiring again, I hope not but could be, good luck and I hope I was helpful
Old Mar 27, 2006 | 09:32 AM
spudsterier
i will have to check them out today, i dont thing that i ever replaced them befor so maybe its time...thanks for the help
