low end power
Old Mar 27, 2006 | 01:58 AM
neonk's Avatar
neonk
Default low end power
i am pretty sure has been mentioned somewhere down the line but since i just joined i wouldn't know about it, my cars low end power sucks major *** until about 3000 rpm, i am have a cold air intake, some headers and a muffler, now i pretty much know that they all help high end power more then low end but before i go out and buy something i want some help from you guys. any help would be appreciated, thatnks in advance.
Old Mar 27, 2006 | 02:39 AM
FuzzRacer's Avatar
FuzzRacer
Default RE: low end power
a pulley would give you some good low end, mabye a bigger throttle body to go with that CAI, A autobody valve could do it to, it changes how the transmission changes so you could get some good line launching from that, hope some of that was helpful
Old Mar 27, 2006 | 03:32 PM
casper's Avatar
casper
Our cars do have a bad low end. A cam, UDP, PCM will all help your low end. Your powerband should be around 3000 - 5500 or so.
Old Mar 27, 2006 | 05:46 PM
neonk's Avatar
neonk
ok thanks for the help people, i now know to buy an UDP. But i have also heard that putting adjustable cam gears on helps the low end if you time them right. I have been looking around and i have found some pretty cheap but i don't want to get them since i don't have a dyno i can use and i don't know what timing to put them at. If i matters, and probably does, i have a DOHC engine. I guess what i am asking is what should i adjust the cam gears to for more low end power?
Old Mar 28, 2006 | 02:48 AM
casper's Avatar
casper
Your gonna need more than a timing gear for low end. It will help to adjust the timing, but not a whole hell of a lot and for the money your gonna spend to get it timed right to get the littlest HP out its gona cost you about $100 a HP for the 5 your gonna get. You want more power? Get a cam or a PCM. Either will cost you about $300 and you can do it yourself and probally gain 15 HP or more.
