A way to fix side piston rod play?
Old Apr 6, 2006 | 09:26 PM
coocoobird's Avatar
coocoobird
Default A way to fix side piston rod play?
I have side to side play where the rod connects to the crank.. I have not checked it yet but if its not the rod thats wore down can i use some kind of piston rod shims on the sides to keep it from moving ? I know that it will be a temporary fix at best and that i would need to get a new crank if this couldnt be done.. Thanks for the help
Old Apr 9, 2006 | 02:31 AM
ewetho's Avatar
ewetho
Default RE: A way to fix side piston rod play?
Time for a crank or new rods depending on which specification is wrong.
Old Apr 9, 2006 | 09:33 AM
highrevr/tflea's Avatar
highrevr/tflea
might as well replace///the rod bearings dont go long w/ your remedy, best to just go w/ a quick change and see what is goin on in there....be sure that it is the rod tho....M'Kay
Old Apr 10, 2006 | 04:03 PM
casper's Avatar
casper
There are no shims, you are gonna have to change the rod or crank.
