cam gears
Old Apr 10, 2006 | 06:29 PM
Womerk28's Avatar
Womerk28
Default cam gears
would you get cam gears on a neon with 150xxx miles?
Old Apr 10, 2006 | 07:26 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: cam gears
No point to really ....unless you do a mild-wild rebuild on the motor ....true time cam gears wont yield any real horsepower gains w/ out tuning.
Old Apr 11, 2006 | 07:54 AM
RadarLove's Avatar
RadarLove
Only if you plan on getting new cams to go with them. And if you have a SOHC, you only need one... and you'll need valve springs unless you get the ZEX/Comp Cams 200...
Best of luck!
