Sea foam
Old Apr 10, 2006 | 11:46 PM
HabitatHxC's Avatar
HabitatHxC
Default Sea foam
Anyone use sea foam to clean out there intake/top end?
im looking to clean my motor and intake mannifold without tearing it appart
Old Apr 11, 2006 | 02:01 AM
ewetho's Avatar
ewetho
Default RE: Sea foam
Old shop several guys swore by it. Worked good and all kinds of black carbon crap came out. Just read directions and all should be OK.
Old Apr 11, 2006 | 02:37 AM
HabitatHxC's Avatar
HabitatHxC
sweet thanks
Old Apr 12, 2006 | 12:46 AM
evilneon's Avatar
evilneon
sea foam?
Old Apr 12, 2006 | 07:29 AM
HabitatHxC's Avatar
HabitatHxC
ya great stuff, you get a can of it (engine cleaner stuff) and spray it into your throttle body, and letter run, i used the whole can. then i let it sit for a while, it seemed to run ok at idle, then i pulled on the throttle cable and it started to work (the motor died down) and i let off the throttle cable and let it idle rough for 15 min or so, then i took it for a drive and shes all cleand up now!
Old Apr 14, 2006 | 12:38 PM
89Daytona's Avatar
89Daytona
http://www.seafoamsales.com/motorTuneUp.htm
The instructions tell you to use the brake booster vacuum line to suck it into the engine, as long as you don't suck it in too fast you will be fine. Expect lots of white smoke to come out the exhaust when it burns.
